AM low voltage varactors
Discussion in 'General Electronics' started by JB, Jul 9, 2003.
  1. JB
    JB Guest
    I am working in a design that requires a low voltage varactor as the one
    used in AM tuning applications. A
    5V tuning voltage could be provided.
    Ideally the diode should go from 47 pF up to above 500 pF. I found a couple
    Sanyo varactor diodes that
    probably could perform that task. These would be the common cathode SVC383
    http://service.semic.sanyo.co.jp/semi/ds_pdf_e/SVC383.pdf and the single
    SVC325
    http://service.semic.sanyo.co.jp/semi/ds_pdf_e/SVC325.pdf
    I would like to find more sources than Sanyo for the required varactor.
    Does anybody know any other manufacturer supplying this kind of devices?
    Best regards,
    JB
