NO, I said extruded heatsinks are considerably heavier than fabricated ones. And less
efficient at transferring heat when using my design. The anodising is a non-issue.
No, IDIOT! The anodizing relates to your remark about insulated contact
surfaces, you total retard!
It is a NON-conductive surface, and the heat source device can be
attached DIRECTLY to it. It couples that heat to the sink BETTER than ALL
the stupid methods you have suggested, so it is certainly NOT a
'non-issue', and for you to say it is is a tell about you.
Everything you ever made was likely a copy of someone else's idea.
If you were any more stupid about this realm, you'd be named Roy.
The word for the day is 'thermal mass'. The determination for the day
is that you are completely clueless as it relates to heat sinking.
Do you even know what the word 'sink' means?
