B
Bob Myers
SteveH said:That would be bubble memory.
Hmmmm....and here I was thinking he meant a PROM
with fizzable links....
Bob M.
This is what I would like. Hardwired logic as opposed to software
You'd have liked plugboard programming.
What is "plugboard programming"? I googled it but didn't receive a
clear definition.
So now the no-ROM issue out of the way?
Yes. As long the ROM-signals are determined by the way the chip's
circuits are mechanically built. When an electric current is passed
through a certain of those circuits, specific signals [of instructions
and information] should be generated.
The only thing I'd like to use magnetic signals for is described in
here:
http://groups.google.com/group/Crea...egen1+magnetic&rnum=15&hl=en#d57c8a76f8118694
Quotes from the above link :
This will cause sample playback MIDI
synths, softsynths, emulations, and soundfonts to be full of annoying
-- and perhaps even frightening -- auditory disruptions from
environmental magnetic interference**."
"**Note: The magnetic signals that interfere with those digital chips
should be purely-analog. I just love it when purely-analog magnetic
signals cause significant disruptions in purely-digital chip-based
parts of electronic devices that I don't like. Sample playback MIDI
synths, softsynths, emulations, and soundfonts are an example of
digital electronic devices that I don't like so I want to victimize
them in this manner -- i.e. via magnetic interferences."
In other words, you would like to effectively destroy the rest of the
world just because they don't follow your preferences. That sounds
like... your full name is really Osama Bin Radium, isn't it?
Bob said:Hmmmm....and here I was thinking he meant a PROM
Bob M.
*YOU* are wasting your time. Radium isn't.
You're the one who has made the CHOICE to waste your time. You can
easily kill the entire thread.
Every participant is in exactly the same position as you.
They have
all decided that it was wort their wasted time to respond.
You have
a problem with that?
If I've responded, it obviously does interest me. Unless you are a
complete idiot, you are no different.
Because you say so?
No, *YOU* have to ignore all such posts if *YOU* don't want to "wasteNo said:Sorry, but you have to ignore all the posts by Radium and
pretend a purpose before that would be true.
Obviously you didn't read carefull, I never wrote it was
solely _my_ time. It's not just my time, it's everyone's,
I know Radium's history. I also know how to use killfiles andincluding news server bandwidth.
Bullshit.
It wasn't a *horrible* problem by any stretch, but then
people like yourself climb on board with opinions that don't
consider Radium's history, the repetitve posting of same
thing nor the conclusions.
Really? I expect some did know about Radium's posting
history but "every"? Doubtful.
Yes, and it was worth my time to respond with the sane
answer instead of senseless wastes of time to coddle a
troll.
Apparently you have a problem, since I was as entitled to
point out Radiums' follies as it is a relevant context to
the posts.
See above, you obviously lack reading skills.
I don't think CPUs (since the Intel Pentium FDIV debacle) use masked
ROM. Or at least, not exclusively.
Large portions of microcode
are loaded by BIOS to permit relatively easy bugfixes. CPU mfrs
provide a binary lump to BIOS writers. AFAICS, the microcode gets
loaded each boot into something analogous to SRAM. (DRAM?).
Or if modifiability is important. It is for CPUs, and probably also
for GPUs.
Alex Colvin, why would I like plugboard? It's not a digital computer
Yes. As long the ROM-signals are determined by the way the chip'sSo now the no-ROM issue out of the way?
Oh, don't worry, mechanical is how all them ROM works, none of them
nonsensical magnetic whatchamacallit you hate so much. You send
specific amount of electron particles constituting a current moving
through nuclear-mechanical paths, it makes other particles move in
predetermined nuclear-mechanical pathways, makes holes so that actual
particles can move around and such, and finally all these
nuclear-mechanics causes specific amount of electrons constituting an
output signal to be produced at the output end.
"Not exclusively" are magic words. I wasn't speaking of any specific
processor except the one in the keyboard. I was trying to keep it
simple to make my point.
Some machines have "loadable control stores". We really don't want to
start taking about them, do we.
I don't think this is what happens.
It is more likely that it is a structure like Flash memory.
You really don't want to have to publish
the fact that your processor contains such stuff unless you really
need to.
Not like redheads! Who could possibly not like redheads?!!The OP wants there to be a physical mechanical difference. He doesn't
like RAMs etc. Chances are he also doesn't like readheads.
like RAMs etc.
and it has no silicon.
I am a fan of real-time digital hardware.
However, the plugboard is totally analog. Sure its hardware, but it
isn't digital.
Actually, I do like RAM, as long as it's in the form of a purely-
electric silicon RAM chip. Now if it's a magnetic platter, then I
don't like it. I long for the day when Flash RAM chips replace
magnetic platters.
The issue was ROM. As I said before, I prefer any digital ROM
"storage" to be in form of chip circuits that freshly-generate
electric signals of information.
Now, if the ROM is analog, I prefer that it be stored in optical
negative B&W film material much the like optical audio tracks of old
B&W movies.
and it has no silicon. I am a fan of real-time digital hardware.
isn't digital.
In comp.sys.ibm.pc.hardware.chips Bob Myers said:Of course the plugboard is digital - you put the plugs in with
your fingers, don't you? What makes you think it's "analog"?
Your longing will be for a *LONG* time. Flash is expensive, compared
to disk. Also note that flash has a fairly short life (100K - 1M
write cycles).
True. Is there a way to increase the life span?
Also, why is it so expensive?
As has been pointed out before, you CANNOT "freshly generate"
information. It must be stored somehow.
Okay. So that's a definite "no".
However, I would like the storage to be as real-time and hardware as
possible. Like the hardware logic I mentioned earlier in this thread.
"Hardwired logic as opposed to software programming. In hardware
logic, the information "stored" and "programming" is determined by the
way the chip's circuits are mechanically built. When an electric
current is passed through a certain of those circuits, specific
signals [of instructions and information] are generated."
This is more what I meant. The above is ROM storage but it is more
dynamic than conventional ROM. This ROM is doing its own processing
right after it's the stored signals are being played back.
No positive color film? Why would you want crude storage like that?
I know it's impractical. Just fun to brainstorm about, though. Whether
the film is color or not, wouldn't matter because video isn't being
stored on the film. Computer data and audio would be. But again, this
is for analog storage only.
