PloddingDonkey
- Dec 3, 2017
- 4
- Joined
- Dec 3, 2017
- Messages
- 4
Hello.
Sorry for not doing my homework but time is a bit pressing.
A friend has a 12V tire pump/compressor, it has burnt out its switch. This is unsurprising as the switch was rated 10A and the motor has a stated draw of 23A, it must be a brute!
Though the pump will not be permanently connected to a battery its case also has a switched light/lamp, so it would be nice to retain the ability to switch the motor on and off rather than simply soldering the motor leads to the leads which connect the pump to the battery.
I volunteered to fix this thinking of using either a 30A relay or a 30A switch but it turns out there is no room for a relay inside the pump's casing and a switch would protrude and be 'inelegant'.
I am now thinking of using a 'transistor' as switch as I recollect this was a possible usage but the bit of surfing I have been able to do suggests I need a mosfet, what the difference between the two is I do not know and is perhaps irrelevant for a one time solution.
The original wiring had the switch on the +ve side of the motor and I would prefer to stick with this layout if possible.
I assume I would need to include some inductive voltage spike protection for when the motor is shut off.
Could some one suggest a circuit and appropriate components.
Thanks and once again I apologise for my lack of research.
