Alternative fet driver
Discussion in 'General Electronics Discussion' started by richardb, Jan 2, 2014.
  1. richardb
    richardb
    48
    Dec 21, 2013
    I've been using a FAN73832MX half bridge fet driver for a few things but it has some limitations when driving anyware near 100% duty cycle does anyone know of a similar alternative that's better? I only need it to work at upto 48v.
    I'm running near 200KHz which is probably why its so bad at high duty cycles. Otherwise it's quite a good chip when working with a pic pwm output
    any ideas?
    Rich
  2. jpanhalt
    jpanhalt
    426
    4
    Nov 12, 2013
    Isn't 100% duty cycle a problem for all bootstrap drives? Moreover, as you surmise, the high frequency probably adds to the problem.
    Just found a driver that kicks in a charge pump to allow 100% duty cycle. I didn't read the whole datasheet, but I suspect similar devices are becoming increasing available to try to get that last percent of power:
    http://www.allegromicro.com/en/Prod...ace-ICs/Brushless-DC-Motor-Drivers/A3946.aspx
    John
  3. richardb
    richardb
    48
    Dec 21, 2013
    yes if they are purely bootstrap.
    I should have added that I have used hip4081 drivers which are excellent but a bit large and pricy.
    i'll have to see if I can find some more info on that part.although at 16 or so pins its already looking less atractive
  4. jpanhalt
    jpanhalt
    426
    4
    Nov 12, 2013
    I would certainly give TI/Fairchild another search. That Allegro part is just the first one that popped up when I searched on charge-pump driver.
    John
  5. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    International rectifier do several devices.
    Thanks Adam-
