Alternate to LM358
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
Hi
I am looking for some alternate to LM358.
I want to use it as an integrator to generate a linear ramp 0-32V (actually 0-30V).
LM358's maximum supply voltage is 32V, and the output is 0-28V.
I need output up to 32V or at least 30V.
p.'s, The alternate part should not be expensive, please.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
You might have trouble finding a cheap one because of the common mode input range of most op amps being less than the supply voltage you need one that does include the supply. I'll have a look for you.
Adam
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
Yes, LT1490A is quite expensive.
Microchip's maximum supply voltage is 16V (as per data shown on their website).
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Unfortunately I think you are going to have to pay a bit more for the op-amp unless you can run the opamp from a slightly higher voltage and then you could go for a standard type. I have had a look quickly on the major players and they all seem to be between £1.50 and the £2.00 mark.
abuhafss
Aug 3, 2010
348
Aug 3, 2010
348
I found two other, MC1556 and MC1558.
