allpass filters
Discussion in 'Electronic Basics' started by Alessandro Esposito, Nov 10, 2003.
  1. HI need to shift the phase of a signal between 0 to 180°. I usually work
    with sinuswave between 10KHk and 100MHz.
    I found out it is possbile to build a so called allpass filter to make this:
    R1
    R1 | | \ |
    Vin ---+ | >--+--- Vout
    C | | /
    / R2
    GROUND
    in which R2 is variable and control the phase delay.
    I have to question:
    1) I do not have formulas to setup the values of C and Ri... is, for
    example, R1 the input impedence of the circuit?
    2) Is it possible to use this circuit up to 100MHz? Which opamp could work?
    A less important aspect:
    I would like to modify this phase via a PC: Do you think is is reliable the
    use of a DAC to control the voltage on a FET base to use it instead (or
    with) R2?
    Alessandro
  2. R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
  3. Sorry... I am not drunked!!! :)
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
  4. Lord Garth
    Lord Garth Guest
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
  5. Lord Garth
    Lord Garth Guest
    You beat me to it!
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
  6. yep of 4 minutes!!!!!
    Did I win the answer? :)
    You beat me to it!
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
    R1
    R1 | | \ |
    C | | /
    / R2
    GROUND
  7. Lord Garth
    Lord Garth Guest
    Sorry, I don't know. :-(
