allpass filter
  • Thread starter Alessandro Esposito
  • Start date
A
Alessandro Esposito
HI need to shift the phase of a signal between 0 to 180°. I usually work
with sinuswave between 10KHk and 100MHz.
I found out it is possbile to build a so called allpass filter to make this:
R1
R1 | | \ |
Vin ---+ | >--+--- Vout
C | | /
/ R2
GROUND
in which R2 is variable and control the phase delay.
I have to question:
1) I do not have formulas to setup the values of C and Ri... is, for
example, R1 the input impedence of the circuit?
2) Is it possible to use this circuit up to 100MHz? Which opamp could work?
A less important aspect:
I would like to modify this phase via a PC: Do you think is is reliable the
use of a DAC to control the voltage on a FET base to use it instead (or
with) R2?
Alessandro
A
Alessandro Esposito
R1
R1 | | \ |
C | | /
/ R2
GROUND
K
Ken Smith
R1
R1 | | \ |
C | | /
/ R2
GROUND
With an ideal op-amp the phase shift of this circuit is 90 degrees at
1/(2* PI * R2 * C). This is the simplest form of the "all pass" filter.
The phase varies quite slowly with frequency. It takes about 2 decades
of frequency to go through 180 degrees.
The form you drew, inverts the input at DC. If you ignore this inversion,
the phase can be calculated with only a little math. The transfer
function of the circuit is:
(1-X)/(1+X)
Where:
X = j * 2 * PI * F / (R2 * C)
Where:
j is the square root of -1 (AKA i in math class)
PI is the usual 3.14159....
F is the frequency in Hz
R
Rene Tschaggelar
R1
R1 | | \ |
C | | /
/ R2
GROUND
I have to question:
with) R2?
A normal multiplying DAC does not handle 100MHz for the reference input.
The fastest one I found was 10MHz.
And yes, there are OpAmps doing 100MHz. Analog Devices have some.
Rene
A
Alessandro Esposito
No.... the DAC should change the phase lag in a slower manner than 80MHz....
At the moment I spend 60ms to change the phase between to phase locked
signal generators controlled by PC... if with a simpler circuit and only one
signal generator I can approch the same speed (or go down) is ok :
