All-in-one question!
Discussion in 'Electronic Repair' started by Rono, Mar 14, 2005.
  1. Rono
    Rono Guest
    Posted this, & got one attachment, but it only shows
    problems, & no actual repair tricks!
    A friend has a Lexmark all-in-one scanner/printer/fax,
    it showed low ink, they replaced ink, & still no printing!
    I know the stand alone printers have the same problems!
    Can you easily clean the print heads? Any common "tricks",
    to get it working? It's in perfect shape! Thanks, Rono.
  2. JR North
    JR North Guest
    Run the Lexmark head cleaning utility. May take several tries.
  3. Jerry G.
    Jerry G. Guest
    All you can do is to run the cleaning utility. Other than that, this means
    taking apart the printer, and trying to clear the nozzles, by soaking them
    in a dissolving solution of some type, and not damaging anything.
    I found this make of printer to not really last very long. But when new,
    they usually work well. There are better printers on the market for a bit
    more money.
    Jerry G.
