Alinco ham radio repair
Discussion in 'Electronic Repair' started by [email protected], Jan 15, 2005.
  1. Guest
    I just went to my first hamfest and I am disappointed. I bought a
    Alinco dr590 that the guy said worked great. WHen I got it home,
    everything in the display lights up, but only sqigially lines where the
    numbers go. Pressing all the buttons does nothing. I can not even hear
    static. I can power it off and on however.
    What could this be and is it repairable? The radio is about 10 years
    old. Can I repair this myself? WHat should I do from here?
  2. James Sweet
    James Sweet Guest
    As with anything like this, it's all sold as-is regardless of what people
    say and you always want to test before purchasing or if the price is right
    buy it assuming it to be defective and take a gamble that you can fix it.
    As for whether you can repair it yourself, do you have a multimeter,
    soldering iron, and some basic electronics knowledge?
  3. Dbowey
    Dbowey Guest
    stryped posted, in part:
    << What could this be and is it repairable? The radio is about 10 years old.
    I downloaded the maintenance documents (PDF - 36 pages) and gave them a brief
    lookover. Unless you have a good scope and signal generator, There is very
    little you can do. If you turn it on and then shake it real hard and you see a
    change in the display, then it might be a loose connector inside you could look
    for; otherwise I suggest you look for help.
    You might post a request for help, giving your general vicinity without being
    too specific, and maybe someone will have the right test equipment and a
    willingness to help.
    Since the seller said it worked and it doesn't, you could contact him to see if
    he will make it right.
    Good luck,
    Don
  4. Guest
    I do have all those and some very basic understanding.
    As a side note it all of a sudden started working when I went back out
    side after posting this email.
    What could it be then? An intermittant problem?
  5. Guest
    Get up with Alinco. My friend has had them do repairs on his radios.
    Do you have the remote cable hooked up, or is it just the radio.
    Come to think of it.... It could also be a dead battery. There is a
    reset command I don't remember what it is , you hold down a button (I
    think function) then press the power button to reset the radio. I had
    that problem with the radio in my truck, when it got cold, the voltage
    on the memory battery went below the threshold voltage, and the display
    would go nuts. I had to reset it ( I did this every time I turned it on
    until I replaced the battery)
    Frank
