hello experts
I want to write verilog code for microcontroller (8051)
I have done little homework
designing controller is not easy so I have divided my homework
first I have developed algorithem
I have applied this algorithm And I made following handy code I know there are so many error
don't write all code for me I need guide to check my homework. I want guide that will give me task to do . I will do homework. how to improve code
I am reading tutorial , pdf files , I am searching this topics on internet
please help me
Code:
(algorithm )
Design for microcontroller
Verilog code
What is Input for microcontroller
What is Output for microcontroller
// I write module for microcontroller
//input deceleration
// output deceleration
// interconnect signal
// I make inner part (alu decoder pc timer….)
// I route all inner part
Endmodule
Code:
// module for microcontroller
module mcu_8051(clk,rst,p0_in,p1_in,p2_in,p3_in,p0_out,p1_out,p2_out,p3_out,rx_in tx_out ,into,int1,to_in,t1_in,wr,wd , op_in, op_out, scr1,scr2,scr3
// input and output declaration
// port
p0_in, p1_in, p2_in, p3_in; // port input
p0_out,p1_out,p2_out,p3_out // port output
// clock input
Clk; // clock input
//rest input
Rst // reset in input
//Uart
rx_in // receive
tx_out // transmit
//timer
to_in, //timer t0 input
t1_in // timer t1 input
// interrupt
int0, // interrupt 0 input
int1 // interrupt 1 input
//alu
src1, // alu source 1
src2, // alu sources 2
src3, // alu sources 3
//decoder
Opcode_in // operation code input
Opcode_output // operation code output
// program memory
Rd_in // read input
adr_o // input
data_out // data ouput
// data memory
Rd_in // read input
Wd_in // write in
Adr_in // address input
Data _in // data input
Data_out // data output
Interconnect signal
input[ 7:0] p0_in
inpu[7:0]p1_in
input [7:0] p2_in
input [7:0]p3_in
output [7:0] p0_out,
output [7:0] p1_out,
output [7:0] p2_out,
output [7:0] p3_out,
wire [7:0]opcode_in
wire [7:0]opcode_out
wire [7:0] acc
wire [7:0] pc
wire [7:0] data_in
wire [7:0] data_out
wire [7:0] scr1
wire [7:0] scr2
wire [7:0] scr3
wire [7:0] opcode_in
wire [15:0]pc ;
// add port p0
Module mcu_port0(input, output)
Input ..;
Output…;
Endmodule
// add port p1
Module mcu_port1(input, output)
Input ..;
Output…;
Endmodule
// add port p2
Module mcu_port2(input, output)
Input ..;
Output…;
Endmodule
// add port p3
Module mcu_port3(input, output)
Input ..;
Output…;
Endmodule
// add alu
module mcu_ alu (a,b,s0,s1,s2 f);
Input a,b,s0,s1,s2;
Output f;
Reg [3:0];
Always @(s0,s1,s2);
Begian
Case (s0,s1,s2);
3b’000 :f=(a&b);
3b’001:f= (a|b);
3b’010 :f= ~(a&b);
3b’011 :f= ~ (a|b);
3b’100:f=(a^b);
3b’101: f=(a*b);
3b’110: f=(a+b);
3b’111:f=(a-b );
End case;
endmodule
//Add decoder
Module mcu_ decoder (a2,a1,a0, d7,d6,d5,d4,d3,d2,d1,d0);
Input a2,a1,a0;
Output d7,d6,d5,d4,d3,d2,d1,d0;
Wire [7:0];
Always @(a2,a1,a0);
Begin
Case (a2,a1,a0);
4’b000: (d7,d6,d5,d4,d3,d2,d1,d0)=00000001;
4’001: (d7,d6,d5,d4,d3,d2,d1,d0)=00000010;
4’b010: (d7,d6,d5,d4,d3,d2,d1,d0)=00000100;
4’b011: (d7,d6,d5,d4,d3,d2,d1,d0)=00001000;
4’b100: (d7,d6,d5,d4,d3,d2,d1,d0)=00010000;
4’b101: (d7,d6,d5,d4,d3,d2,d1,d0)=00100000;
4’b110: (d7,d6,d5,d4,d3,d2,d1,d0)=01000000;
4’b111: (d7,d6,d5,d4,d3,d2,d1,d0)=10000000;
Endcase
endmodule
//add counter
module mcu _counter(current state, next state ,clk)
input current state ;
input clk;
output next state;
reg 3:0
always @ (posedge clk);
begin
next state <= current state +1 ;
end
endmodule
End other component
endmodule
please help me
