OK, so it's not recommended by mine. What's your point? You said that all
companies should just use it to be standard. Just like here in the US, UL,
CE, ULC (for them clean air guys), NEC, NFPA, BOCA, etc, etc., these are
minimum standards for guidelines. It doesn't mean follow them to a "T", it
means at a minimum. If your Manufacturer states to use it, then use it.
Depending on the type of data your systems communicate on, it would be a
standard, but it's not a standard for every Manufacturer. You can follow a
standard, and still install something incorrectly. I'm quite certain that
their are some European (imported or not) Manufacturers which utilize data
communications that recommend NOT to use shielded wire. The other mistakes
people make is using the "drain" wire, as a ground, and grounding it at both
ends. I'm not saying you do, but a majority of people (companies) do. The
effects of RFI/EMI at that point, are the same as not using a shielded wire
at all. The point is, is that it should be done correctly, either way, and
not just by a company policy. If you are using shielded wire, installing it
correctly, and following a Manufacturers Recommendation and it works, it
means you've installed it correctly, that would be a good standard to
follow. On the other hand, if your competitor is using a different
Manufacturer's method, which costs less to install, you may be at a
disadvantage with an across the board standard using only shielded wire. The
same can be true for Plenum vs. CL2.
Jack
BIG NIGE said:
Shielded cable is recommended by the MANUFACTURER of the id systems we
use.
Shielded cable is recommended by the MANUFACTURER of the non id systems we
use for situations where you have a risk of interference (including not
being far enough away from other cabling.
Peter said:
If you fit any I.D. systems it is always better to use screened
cable all the time
If you cannot get far enough away from other cabling Mains,
Telephone, Data Etc it is also better to use screened cable
with all alarm systems (shop around for your screened cable,
prices vary greatly)(but dont mean get cheap QUALITY cable
i mean get quality cable cheaper)
Sorry, but I disagree, friend. Many alarm systems should NOT have shielded
cable on the keypad runs. It can actually cause more problems than it
solves. Use the cable specified in the manuals. You can use EMT if you
need physical and EMI shielding, but avoid using shielded wire for data
busses unless it is specified.
Regards,
Robert
[Within European Union]
It might depend on the manufacturer but for compliance with revised
CE-directive it could be a must to use shielded cable for remote bus and
external outputs.
Kind rgds
Peter
