Akai TV probs
Discussion in 'Electronic Repair' started by Greg, Jan 31, 2005.
  1. Greg
    Greg Guest
    All,
    I have an Akai TV and seem to be having a bit of a problem with the picture
    when I turn it on and for about 10 mins afterwards. I get white interference
    lines and the picture breaking horizontally. What is curious about it is
    that the rythmn of the interference is in time with the bass of the sound
    coming from the TV. If I turn off the sound, the interference goes...
    Any thoughts? Would it be expensive to repair?
    Greg
  2. Guest
    is this an ITT nokia chassis?
    could be loose connection or bad soldering on the tuner /in the IF
    section, and vibration from speaker is causing pic interference.
    if it has horizontal tearing, replace c625 (if you have the 110º core
    chassis that is!)
    regards, Ben
  3. Bad connection, or the dust/EHT problem discussed last week.
  4. Jamie
    Jamie Guest
    cracked solder joint, bad connection.
