Aiwa turns back on after turning off
Discussion in 'Electronic Repair' started by [email protected], Nov 23, 2012.
  1. Guest
    I have an Aiwa CX-NAJ14, that turns itself back on after turning it off. It doesn't matter if it's turned off via remote or the front panel power button. The display says "good-bye" as most Aiwas do, displays the time, thenabout two seconds later it powers back up again. I haven't pulled the cover off, but this seems odd. Maybe bad electrolytics? Has anyone ran across this problem before, or have a schematic for this unit?
  2. Guest
    Ha ha, just fixed it. It's amazing how typing about a problem gets the mind working. I thought maybe it wouldn't turn off because the time wasn't set, and wouldn't you know, that did it! Amazing...so simple! Way too oftenI ignore easy, obvious stuff.
  3. hr(bob)
    hr(bob) Guest
    Well, it sorta makes sense, it is telling you to set the time, bet
    that's buried somewhere in fine print in a footnote in the instruction
    manual, maybe even in English<g>.
