Aiwa HV-MX1 FF/REW problem
Discussion in 'Electronic Repair' started by DaveH, Aug 25, 2004.
  1. DaveH
    DaveH Guest
    After 8 trouble free years my Aiwa HV-MX1 VCR has started having
    intermittent problems with FF and REW. Sometimes it works fine other
    times it will not FF or REW.
    When it fails the take up spool (terminology?) will spin slower than
    normal and the free running spool (terminology?) will have the brake
    applied. The brake is stronger that the take up so the tape does not
    move at all. The mechanism, however, continues to try and drive it
    until you intervene. Simply press STOP and it may work properly on the
    next try.
    Anyone got any ideas what may be causing this behaviour. Is it likely
    a logic issue i.e. the processor or a feedback problem i.e. mode
    switch or something else altogether?
    All other functions appear to work correctly.
    TIA,
  2. Asimov
    Asimov Guest
    "DaveH" bravely wrote to "All" (25 Aug 04 10:35:13)
    --- on the heady topic of "Aiwa HV-MX1 FF/REW problem"
    Da> From: (DaveH)
    Da> After 8 trouble free years my Aiwa HV-MX1 VCR has started having
    Da> intermittent problems with FF and REW. Sometimes it works fine other
    Da> times it will not FF or REW.
    Da> When it fails the take up spool (terminology?) will spin slower than
    Da> normal and the free running spool (terminology?) will have the brake
    Da> applied. The brake is stronger that the take up so the tape does not
    Da> move at all. The mechanism, however, continues to try and drive it
    Da> until you intervene. Simply press STOP and it may work properly on the
    Da> next try.
    Da> Anyone got any ideas what may be causing this behaviour. Is it likely
    Da> a logic issue i.e. the processor or a feedback problem i.e. mode
    Da> switch or something else altogether?
    Da> All other functions appear to work correctly.
    Maybe the mode switch needs cleaning?
    A+s+i+m+o+v
    .... If all else fails, hurl it across the room a few times!
  3. DaveH
    DaveH Guest
    Thanks for the pointer Asimov. Cleaned it up and now it works
    perfectly. I didn't even consider that the switch would be so easy to
    disassemble for cleaning. Now getting to it, that was another matter!
