N
N Cook
b said:N Cook ha escrito:
I don't understand. have you replaced the belts with new? if so,
nothing should be falling off and nothing will need modifying.
-B.
both new bands and cleaned pulleys. moving from REW to play causes the band
to fall off, presumably due to a snatching / breaking / imbalance associated
with this double connection to the tape presumably at take up.
If I put in a guide then it can't fall off and will presumably self centre
back up the vague hump on the periphery of the "reverse" flywheel.
On baluster/ bulbous motor pulleys they usually have a preventer disc either
side of the bulging active part. This pulley has a larger pulley on one side
but nothing on the other in the way of a preventer.
