Moving_Shadow
- Sep 29, 2012
- 7
- Joined
- Sep 29, 2012
- Messages
- 7
Hi guys,
Not sure if this is in the right place, so I apologize to the mod who has to move it if it is. Also, if posting topics related to airsoft isn't allowed, feel free to delete this thread.
I have a Classic Army M249 AEG, which uses a drum magazine to feed the bbs onto the gun, using a servo. The gun itself runs from a 10.8v 500omAh battery, and the drum magazine runs from a 9v battery. Currently the trigger on the gun isn't connected to the magazine, but I would like to connect the two, so that when I pull the trigger on the gun, the servo in the magazine winds and feeds the bbs to the gun.
The drum magazine has a button that when pressed, engages the servo, winds up a coil, and this feeds the bbs to the gun, I need to keep this button, because its required to "spool" up the coil before pulling the trigger, so I would need to press this button until the requires tension is met, then when I pull the trigger on the gun, it would fire, and keep the required tension on the coil.
I know what needs to be done, I just have no idea how to do it, so I'll leave it to the experts. I can provide any information required, or pictures if needed.
Thanks in advance for all your help.
