Categories
Platforms
Content
Small enough to fit in small tube about twice the size of a straw. The switch just needs to turn on a chip that controls the Vape mod its self. Price.... For prototype 10 bucks. At bulk $1"small air actuated switch"
How small?
What voltage and current switch?
Maximum price?
Ken
Op is looking at changes in air flowConsider a thermistor with a suitable circuit.
Yes, he is wanting to detect flow. Heated thermistors will change temperature and therefore resistance with flow. I used such a device to measure wind speeds on a vehicle close to the brakes. It became known as the bee catcher.Op is looking at changes in air flow
For one you can use a barometric pressure sensor. It will not detect the flow of air but the change in air pressure which is imho suitable for your application.
Or use a fork sensor (like e.g. this one) and add a small flap that is outside the sensor's light path when no air flows, buit is drawn into the sensor's light path by the flow of air, thus interrupting the ligt path and giving a sensor signal.
Needs to supply continuos signal to the boardBerry,
Must the switch maintain a closed contact while there is an increased negative pressure/flow or can it be a momentary pulse closure?
Ken
These are amazing however very cost prohibited. The type of switch I am thinking of is all ready in use for corner store ecigs I am just not sure what they use.For one you can use a barometric pressure sensor. It will not detect the flow of air but the change in air pressure which is imho suitable for your application.
