Ainol novo 7 Paladin LCD brightness
Discussion in 'Troubleshooting and Repair' started by rbreznik, Sep 5, 2012.
  1. rbreznik
    rbreznik
    Sep 5, 2012
    Helo.
    I have problem with LCD brightness.
    In rectangle area, is high pitch noise and brightness goes only to 30%. Something is burned.
    I would like to find datasheet for BT=R1 chip.
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    I can tell you right now that high pitch whining is more likely than not a capacitor
    Look at and test the caps, that would be your most likely culprit
    this would also help explain the dimness, PWM (if it uses that) would be affected by a cap
  3. Jotto
    Jotto
    120
    Aug 24, 2012
    It looks like your at the panel of the LCD. Brightness is controlled by the A/D board and inverter. I don't know what voltage your using.
    First I would determine if you inverter is working properly. You can run the inverter without anything else attached except the lamps. First determine your voltage required. Some units are set up kinda strange when it comes to the main power in and switched voltage.
    Lets say you have a 12vdc input, and a 5vdc switched voltage. You could run this off 1 12vdc power supply and use a resistor to drop down for the switched voltage. This is just a example, you will need to get the correct readings with your meter. Brightness is sent from the A/D board to your inverter. The panel just processes the video.
  4. Jotto
    Jotto
    120
    Aug 24, 2012
    Lets say you have a 12vdc input, and a 5vdc switched voltage. You could run this off 1 12vdc power supply and use a resistor to drop down for the switched voltage. This is just a example, you will need to get the correct readings with your meter. Brightness is sent from the A/D board to your inverter. The panel just processes the video only.
