T
Tim Polmear
Hello
I wonder if anyone can give some advice regarding a little problem.
I have a couple of CRT monitors that exhibit similar problems. One
flashes yellow (blue gun fault I guess) and the other flashes magenta
(green gun fault?). It seems to be an electromechanical fault because
both monitors respond to percussive maintenance, but the problem soon
reappears. The monitors are a few years old.
Can anyone guess what the problem is likely to be and do you think it
would be worth having them repaired? (The answer to the latter is
probably no.)
Regards,
Tim Polmear
probably no.)
Regards,
Tim Polmear
