B
Ben
Hi all,
I'd much appreciate any advice on my search for a cheap and simple pressure
sensor. I need to make a device which can measure how hard a baby is
squeezing a silicon tube, around 2cm thick. I figure the best way is to
connect the tube via a pneumatic tube to a pressure sensor. So what I need
is a pressure sensor that does not have to be accurate in absolute terms,
but needs to be relatively sensitive, so it can measure changes in grip
strength. I reckon if it went up to 1000 kPa that would be more than
enough. Preferably it would come with an integrated USB interface and
drivers which provided an API. Alternatively, if you know a good one but it
just outputs a voltage, perhaps you could also recommend a good cheap and
cheerful USB A to D converter?
So far the best thing I've found is this, which you can combine with a USB
interface from the same supplier:
http://store.pasco.com/pascostore/showdetl.cfm?&DID=9&Product_ID=51374
&Detail=1
But I think it will only interface using their proprietary software - it's
for classroom use, after all. But this gives you a basic idea of what I'm
after.
Other solutions to the basic problem also gratefully received!
Cheers,
Ben
&Detail=1
after.
Cheers,
Ben
