T
Tim Mackinlay
What is the best panel (in the 80 to 100 watt size) to use where the
panel might get shaded? It's for use on a sailboat.
Tim
Tim
Tim
R.E.P.C.O. said:never ever try and get a warranty claim on a Unisolar panel as Unisolar
never have warranty claims and you are left high and dry with Unisolar hosed
panels.
Unisolar have even changed to metal that rusts and of course it will not be
their problem
The other issue with Unisolar they fail to publish their proper temperature
ratings on their website as in cold to cool conditions Unisolar is useless
garbage.
There is no panel that is any good for partially shaded use
Have you considered why there are no other mainline panel manufacturers that
make garbage like Unisolar
PVDanno said:I currently use a "normal" silicon panel (blue colour) and a smallerpanelsfilm
(brown colour), tested both by partially shading with a thick towel. The silicon
panel's output dropped significantly, almost completely IIRC, while the film
performed admirably, almost no change in output. Both are made by ICP.
I recently spoke with my PV dealer, he suggested Unisolar amphrous
Tested how?
What output were you measuring?
You can't shade a panel
without affecting its power output. The best you can hope for is that if
you block, say, 50% of the incoming light the panel's production will
not drop by more than 50%.
If you are shading a panel and seeing almost no change in output, I
suspect you are measuring open-circuit voltage. That might give you some
idea how the individual cells inside the panel are interconnected, but
it won't tell you much else. Try repeating your experiment and measuring
short-circuit current. Better yet, repeat it and measure both voltage
and current while the panel is loaded.
As long as bypass diodes are correctly installed, crystalline silicon
panels should function just fine under partial shading. And I've seen
several crystalline panels with bullet holes that were still functioning
at 50-75% capacity. It was the ones that were kicked in with combat
boots that didn't want to work anymore....
What you are overlooking here is the fact that some panels have internal
bypass diodes around each cell. That I am sure is the one that dropped 30%.
When you shaded the other one you essentially turned off that cell, and with
no bypass diode in the panel, the output from ALL the cells was reduced, as
it all has to go through that turned-off cell.
It is a function of panel design, not of what the panel is made from.
