Advice about MC34063 based buck converter diagram
Discussion in 'Power Electronics' started by HellasTechn, Apr 10, 2019.
  1. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Well i am alredy using the pin's method to connect my boards. I have the arduino board, one Interface board and one I/O board all connected "back to back" so i would like to have the PSU biult in the I/O board and not as separate board.
    Purely due to my projects design.
  2. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    I received the 34063 today and started experimenting on the breadboard.
    I used the values recommended by the design tool. I gave it the following parameters:
    Vin=12V
    Vout=5V
    Iout=500ma
    Vripple=60mv
    So it gave me the following values:
    Ct=947 pF
    Ipk=1000 mA
    Rsc=0.3 Ohm
    Lmin=142 uH
    Co=104 uF
    R1=1k R2=3k (5V)
    Now i used a coil of 200uH, Ct 1000pf instead of 947pf and Co=220uf (also tried 1000uf)
    without any load connected it shows very large ripple on the output (about 200mv pk-pk).
    What am i doing wrong here ?
  3. WHONOES
    WHONOES
    882
    216
    May 20, 2017
    Put a load on the output. It could be the error amplifier having a bit of a struggle with the fact you have no load on you supply. They tend to spend a lot of time turning on and off in that situation instead of exercising a more linear control. It might also be that any compensation is not correct. SMP's tend to be a bit noisy anyway, it's just a matter of scale.
    A final thought. Is the ripple H.F or a somewhat lower frequency? is it spiky or rippley?
    Can you get a pic of it?
  4. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Yes i can get pictures. It looks ripply to me. At the moment i am going through my connections again to make sure that i have everything okay on the breadboard. I do suspect the breadboard itself causing this though.
  5. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Adding a 100nf ceramic capacitor between pin 1 and pin 2 seems to help alot but still after adding load (the actual arduino board with an LCD) things get really ugly.
    all pictures are with the load attached.
    picture 0 shows the output with a 220uf output capacitor.
    picture 1 shows the output with a 1000uf output capacitor.
    picture 2 shows the output with the 100uf cap and a 100uh inductor (terrible)!
  6. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Okay. i used the diagram as in the datasheet with slight modifications as shown below and i got it working. now i will try adding the optional output filter to see what happens.
  7. WHONOES
    WHONOES
    882
    216
    May 20, 2017
    Try a larger cap on the output. I have just designed a switcher in simulation,for use with gloplugs for my model aero engines to use with a 12V battery. It supplies up to 15A or so at between 0.9 to 1.5V. It runs at about 120KHz and has 2 2200uF caps on the output. I have bee investigating a filter on the O/P as well but am not certain that it is worth the extra components. It too produces ripple similar to your at a light load as the error amp turns the PWM on and off because of the light load. So, as I said in a previous reply, you need to load the O/P so that the error amp is not forcing the PWM to be switched on and off in order to control the O/P.
    The inductor looks a bit large in value which can affect ripple. What is the switching frequency of your circuit?
  8. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    i think it is 40Khz. since Vin=12V Vout=5V and Ct=470pF.
    The problem is that i do not have good quality low ESR capacitors...
  9. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    I wonder how the capacitor i placed between pin 1 and pin 2 affects the circuit and reduces ripple. I saw it in a car USB charger that i have...
  10. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    I should probably make a new thread about this question but anyway. I see that the buck converter is noisy no matter what so im thinking that since my project is of big importance and i need tie microcontroller to be as reliable as possible. i could try feeding the 12V to an 7809 Vreg which in turn will feed the 7805. this way heat dissipated from each chip will be significantly less that the heat dissipated
  11. WHONOES
    WHONOES
    882
    216
    May 20, 2017
    You could try a parallel resonant filter in series with the output. It does work. You have to tune the filter to the fundamental of the ripple. It works by presenting a very high impedance to the ripple. The only downside is that it only works at one narrow band of frequencies and if there are significant harmonics above that, they won't be affected.
    The formula to calculate is (1/6.284) * (SQRT (C*L)), where C is expressed in Farads and L is expressed in Henries.
    3.3μH in parallel with 4.7ΩF will resonate at 40.4KHz which is close to your quoted value. Note, the Inductor should have a very low DC resistance, preferably in the low milliohm region as this will affect the Q of the circuit.
  12. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    It looks like that i am not able to measure the ripple with the Oscope. I have builded the circuit on a PCB and things are alot different now. I will show pictures.
    (*steve*) likes this.
  13. Bluejets
    Bluejets
    4,045
    843
    Oct 5, 2014
    You could be sweating over nothing here.
    All the Arduino I've ever worked with will take 12V comfortably on the RAW input, no need for any converter.
    Think you are a bit off with the current consumption of the Arduino.
    The 328 draws maybe 25mA.
    http://www.home-automation-communit...n-atmega328p-for-a-year-on-coin-cell-battery/
  14. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Maybe but i am not sure. I will explain.
    I use the arduino mega 2560 (pro mini boad) like this one:
    https://www.makerlab-electronics.com/product/arduino-mega-2560-pro-mini-atmega2560-16au-ch340g/
    Also i have in use many inputs - outputs plus i have other attiny chips powered from the same source.
    The atmega board in its back it states that the working voltage is 7V-9V (peack 18V).
    So i do not think that the onboard regulator can handle this current.
