R
Radium
Hi:
Below is an example of "parallel Hz"
http://img56.imageshack.us/img56/2427/clocksignalexample8is.gif
If each clock signal is 1 Hz, and you have a billion of them,
staggered such that every 1ns part of the CPU can start, and finish,
an instruction - making the effective 'clock rate' 1 GHz.
The benefit of using a billion 1 Hz clock signals to make a clock rate
of 1Ghz is that such a system would not get as hot as system running
one 1 GHz clock signal . While the overall amount of heat generated by
both systems maybe around the same, the system running a billion 1 Hz
clock signals will have less heat per area than the system running one
1 billion Hz clock signal. Hence, the former system is far less
vulnerable to thermal damage than the latter.
Let's say two CPUs of different frequencies have been running at the
same voltages and amperages and for the same amount of time. The CPU
with a higher-frequency will be hotter than the CPU with a lower-
frequency.
In a "parallel Hz" device the bits maybe completely in serial and the
algorithms and tasks maybe totally non-parallelizable. However, the
frequency is still parallel.
The device I am proposing is completely serial except for the clock
rate.
My proposed device is completely serial except for the frequency. It
uses "parallel Hz" but in terms of everything other than frequency, it
is totally serial and non-parallel. Only the clock rate is parallel.
Parallel Hz = a method using N number of 1 Hz clock signals to gain a
clock rate of N Hz.
My design has a clock rate of 4 GHz that is obtained by using 4
billion 1 Hz clock signals. But otherwise, it is completely serial.
This design would go great for any application that cannot be
efficiently parallelized [in terms of bits]. Examples of such are
arithmetics and Boolean logic. Parallel Hz would work for serial-only
problems because the bits are still in serial. Parallel Hz does not
require that the bits be parallel.
There is a significant difference between "parallel Hz" and "parallel
bits".
A parallel printer is an example of a device that uses "parallel
bits". This has nothing to do with "parallel Hz" because both serial
and parallel devices can use parallel Hz.
Radium
frequency.
rate.
clock rate of N Hz.
bits".
Radium
