I think it looks nicer, but functionally I don't believe there is any
difference. Both methods keep the wires neat and organized.
Indeed there is a difference, notably in the aviation world.
Look inside the avionics bay of a commercial jet sometime. Come to
think of it, look at the innards of any piece of older avionics gear
that uses point-to-point wiring instead of, or in addition to, a printed
circuit backplane. What you'll see is the absence of tie-wraps, and an
abundance of laced cable harnesses.
I used to work at Boeing, and I had some friends in the Wire
Design group. I asked about this very question once. I was told that
tie-wraps are not favored for two reasons.
(1) If the tension on the tie-wrap is too high, it can crush
fragile coaxial cables.
(2) It's much easier to damage wire insulation under tie-wraps in
a high-vibration environment. Lacing twine is nowhere near as sharp
along its edges, and thus does not nick or cut said insulation.
Keep the peace(es).
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm --
www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
