ADT New Installation - Keypad not Powered Up
Discussion in 'Security Alarms' started by [email protected], Sep 24, 2005.
  1. Guest
    I bought a house with an existing alarm installed by ADT. It is a
    DSC1550 model, and the keypad is the simple one with the upright oval
    buttons F A P at the bottom.
    To my knowledge, this system has never been monitored, but is fully
    wired according to the Brinks service tech that did the inspection
    prior to buying the house.
    However, the keypad is not powered up. I have traced all the wiring
    with a tone tester, and verified the system has power and there's power
    going to the keypad.
    I don't want a monitoring service. I want to do it myself with a
    program me and my friend wrote to interface the alarm system to a PC
    via serial port.
    My question is, how do you get this keypad powered up? Is there a
    multibutton sequence to push and then a master code? I would need that
    too. Once I get that far, I have the manual to configure it.
    There is no phone line hooked up to it at this time either, so I'm not
    worried about ADT finding out I've done something or triggering a
    police dispatch. As far as I'm concerned, I own it and can do what I
    want with it.
  2. Crash Gordon
    Crash Gordon Guest
    inline...
    Those Brinks inspections are just a joke to get their foot in your
    door...somehow they get leads from Realtors, often if you decide to go with
    them they want to remove the system that is already there and install one of
    their proprietary systems. </rant>
    Sometimes ADT will leave the keypad wiring disconnected behind the
    keypad...check that. OR...a Realtor disconnected it because it was beeping
    for low battery, power fail, fail to communicate.
    | via serial port.
    Good luck.
    Check the wiring at the keypad.
    | want with it.
    Go for it!
