Karthik rajagopal
- May 9, 2016
- 257
- Joined
- May 9, 2016
- Messages
- 257
Hi all,
Recently while referring to TLV1117 adjustable voltage regulator from Texas Instruments, I came across its functional block diagram.
The following questions came up to mind with regards to its working:
1. The package has only 3 pins among which none connects directly to ground. Then how is the internal op-amp powered?
2. If the op-amp is powered by the potential difference between its output and input, then how will it get powered ON initially since the op amp controls the BJT that connects the input to the output?
Datasheet: https://www.ti.com/document-viewer/TLV1117/datasheet/abstract#SLVS2972356
Any related documents would also be helpful.
Thanks in advance.
Thanks in advance.
