Adjust COnvergence on Viewsonic P815 CRT?
Discussion in 'Electronic Repair' started by Jaime Pirnie, Nov 24, 2004.
  1. Jaime Pirnie
    Jaime Pirnie Guest
    So my wife and I both have Viewsonic P815 21" CRT monitors. We've had them
    for a number of years. They are both getting farther and farther out of
    convergence. The screen is out of convergence in different areas of the
    screen so adjusting the convergence with the OSD just fixes one area and
    makes the other areas worse.
    Does anyone know a way to adjust the different areas? I'm guessing that I'll
    have to pull the back off the monitor if needed. I'm also fully aware of
    the flyback transformer that's in CRTs so I'll be pretty careful about
    sticking my paws in there. I also use plastic tools for turning pots and
    stuff.
    Any help or guidance would be appreciated. If there is another public
    folder that this would be better for, please let me know.
    Thank you, Happy Thanksgiving,
    -Jaime
  2. James Sweet
    James Sweet Guest
    This is a Trinitron monitor right? Is the convergence problem horizontal or
    vertical? Does it change at all as the monitor warms up? You have to be
    careful trying to adjust out a fault like this, sometimes it's a number of
    components experiencing normal aging and an adjustment is appropriate, but
    often something is much further out of tolerance, such as an electrolytic
    capacitor that's dried up and adjusting is a temporary fix at best and can
    make the problem worse.
    If it's just the horizontal convergence, most Trinitron tubes have a pot on
    the neck board that can be adjusted which may fix your problem, at any rate
    if the user controls won't fix it you'll have to pop the top and have a look
    inside.
  3. Jaime Pirnie
    Jaime Pirnie Guest
    I'll make sure tonight to let it warm up for about a half hour or so and
    then take a closer look at exactly where the adjustments are needed. The
    last time I looked it was near the edges of the screen but I'll take a look
    again and see exactly where things are out of whack. I think it is a
    Trinitron tube yeah. This wasn't something that just happened it's been
    slowly happening over time so I think if I can adjust it I might be able to
    get some more time out of this thing.
    -Jaime
