ADF7011 433MHz transmitter
Discussion in 'Electronic Design' started by Rene Tschaggelar, Mar 2, 2005.
  1. There are these extremely simple to apply transmitter chips
    such as the ADF7011, which are a 76kbit transmitters including
    VCO & PLL. A few R & C and you're done. This gives me complete
    transmitter on a thumbnail, just the actual microcontroller
    delivering the data is to be added plus a quartz signal. 30mA
    supply at 3V and it costs 4$.
    Now comes the stupid part. How am I expected to receive the
    signals ? Yes, I could build a PLL with a VCO, crystal, then
    perhaps an AFC to lock to the frequency unless I'm hopping
    the freqeuncy. Downmix to whatever and decode the bits.
    It takes few hundred mA and perhaps a handsized pcb.
    Or downconvert with a PLL multiplied Quartz from a DSP,
    sample at few MSamples and have some code to extract the bits.
    I'm somehow expecting a thumbnail sized receiver equally
    trivial to build like the transmitter. No ?
    Did I miss something ?
    Rene
  2. Tim Wescott
    Tim Wescott Guest
    Linear tech, Maxim, and I think ADI, have some direct-conversion
    quadrature receivers that'll get you down to baseband -- decoding the
    data is your job, but it should be quite doable with a DsPIC, other
    small DSP, or (gasp) analog circuitry.
  3. nope, AD only seem to make TX's or RX/TX
    http://www.analog.com/en/prod/0,2877,ADF7020,00.html
    but no RX's
    so you might need a transceiver strapped into RX mode.
    Dumb eh?
    martin
    "An eye for an eye makes the whole world blind"
    Gandhi
  4. Apparently. They somehow figured the need for a receiver
    to be (much) smaller than for transmitter or transceivers.
    Or they figured it to be done differently, such a with an
    ADC at a subharmonic.
    Rene
  5. Luhan Monat
    Luhan Monat Guest
    Maybe some of these...
    http://www.radiotronix.com/prodsel.asp
