Ademco Lynx (Rev. 10)
Discussion in 'Security Alarms' started by newb, Jul 11, 2007.
  1. newb
    newb Guest
    howzabout pager format
  2. Thats not one of the options. Only radionics and ademco formats other than
    contact id.
  3. I have an ademco lynx, it reports to my alpha pager (motorola advisor elite)
    via numeric at this time. I was told that it may support alpha numeric
    paging that I need to get the modem access number to my pager (which i've
    done) and program it to do so. I looked into the programming of my panel
    using compass and I'm not sure if it actually does support alpla numeric
    paging or which setting to use if so (i.e. contact id report, ademco low
    speed, etc.) any help much appreciated.
  4. Buggs
    Buggs Guest
    Sure it does, Mark. Just go into programming section 109 and enter the
    "change format" code. I believe it's 8888. Then power down, wait exactly
    seven minutes, and power up with the battery only. Wait another seven
    minutes and connect AC, but you have to connect both legs at exactly the
    same time. Remember, just like the old Vista 1 series.
    js
  5. Crash Gordon
    Crash Gordon Guest
    7 minutes?...thought it was 3.5 then 3.5 for a TOTAL of 7
    Rob
    Microsoft MVP - FrontPage
    | >> advisor elite) via numeric at this time. I was told that it may
    | >> support alpha numeric paging that I need to get the modem access
    | >> number to my pager (which i've done) and program it to do so. I
    | >> looked into the programming of my panel using compass and I'm not
    | >> sure if it actually does support alpla numeric paging or which
    | >> setting to use if so (i.e. contact id report, ademco low speed,
    | > It doesn't
    | js
  6. Buggs
    Buggs Guest
    Been a long time, you might be right.
    js
  7. Buggs
    Buggs Guest
