Ademco Lynx No Pager function
Discussion in 'Security Alarms' started by kchmch, Dec 26, 2003.
  1. kchmch
    kchmch Guest
    I just bought a Ademco Lynx system from Ebay. I can not get the panel to
    page my cell phone. I enter data as follows
    7 in data field *49
    1 in data field *87
    my cell phone numbers in data field *42
    I then unplug the telephone wire from my land phone and plug the RJ11 into
    the 8-position jack of the panel. I then press and hold the AUX button for
    at least 5 seconds. I even try to fault some zone to trigger an alarm and
    see if the panel page my cell phone. I have try to enter my other land phone
    number in data field *42. So far I have not got any luck.
    Does my panel has some burn-in number? Is the modem broken? The Lynx panel
    was dated around 1998. Could the paging feature is not available for this
    early model? I appreciate any DIY expert could offer any help. TIA
    KM
  2. A.J.
    A.J. Guest
    If I remember correctly, the paging function on the Lynx will not work
    unless you subscribe to monitoring service.
  3. schism
    schism Guest
    If I remember correctly you have to have a CS programed into field 43
    before it will dial out. so put your pager into field 41 and a number
    you can remember into 43.
    Bill
  4. Me
    Me Guest
    LynxR
    Programming Paging Feature
    Step 1: Test pager for compatibility, call the pager & enter a few
    digits then press [*] if the pager disconnects after press
    the [*] key this pager will not work! If it does not disconnect this
    pager will work
    Step 2: Enter Program Mode: Installer Code (4112) + 8 + 0 + 0 If this
    key sequence does not work or you do not know
    the installer code you can power down the system (AC & DC) then power
    back up & within 50 seconds press & hold the
    [*] + [#] keys simultaneously for about 5 seconds this should get you
    into program mode. If not then the panel may have
    been locked out of keypad programming.
    Step 3: Press [*] 42 & enter the pager phone number, if less than 20-
    digits press [*]
    Step 4: Press [*] 43 & enter the account number
    Step 5: Press [*] 48 & enter 7 for contact ID reporting
    Step 6: Press [*] 49 & enter 6-9 depending on what you want sent to the
    pager
    6=All reports except O/C to primary – Alarms, Troubles, & O/C for users
    5-25 to Pager
    7=All reports to primary – Alarms & Troubles to Pager
    8=All reports to primary – Alarms, Troubles, & O/C for users 5-25 to
    Pager
    9=All reports except O/C to primary – O/C reports for user 5-25 to Pager
    Step 7: Press [*] 87 & if ONE-BUTTON Paging is desired (sends 999-9999)
    then enter 1
    Step 8: If extra characters are needed before the account number like a
    pin number or other digits are desired press [*]
    88 & enter up to 16 digits, if fewer than 16-digits press [*]
    Step 9: Enter ANY reporting codes needed if sending reports to the pager
    Step 10: Press [*] 99 to exit program mode
    NOTES:
    • Pager will display:
    AAA-EEE-00NN
    A=16-digits programmed in *88
    E=3-digit number describing events:
    911=Alarm
    811=Trouble
    101=Open
    102=Close
    N=User number or Zone number
    • If the [AUX] key was setup for 1-button paging the pager will get 999-
    9999
    • If you do not get the full message sent to the pager insert a pause
    after the phone number in field 42 by pressing
    [#] 13, each one of these entered is a 2-second pause
  5. Me
    Me Guest
    you do not need a primary number for paging to work!!!!!
  6. Me
    Me Guest
    One more time
    Page 1 of 1
    LynxR
    pager will work
    digits press [*]
    pager
    5-25 to Pager
    Pager
    then enter 1
    NOTES:
    AAA-EEE-00NN
    911=Alarm
    811=Trouble
    101=Open
    102=Close
    9999
