Ademco 15p and AD-2001 Dialer
Discussion in 'Security Alarms' started by carolinaoff, May 14, 2009.
  1. carolinaoff
    carolinaoff Guest
    Have a 15p using a 4204 relay module connected to a AD-2001 dialer. When
    the alarm trips it calls the programed number OK but hangs up
    immediately. 15p is set to 2 second close on alarm. Any hints on why the
    AD-2001 does not play the OGM. Thanks JB
  2. mleuck
    mleuck Guest
    10 minutes eh? He might want to check programming of the dialer first
    don't you think?
    Maybe Step #7 might be a good place to start
  3. carolinaoff
    carolinaoff Guest
    Appreciate the replies but it appears the problem may be in the dialer.
    Disconnected the alarm, using only power and telephone connection I run
    the test, shows set OK plays message through speaker but calls and hangs
    up before the message is played over the phone.
    TLine: Tone, PBX off, Attempts 2, Repeats 3
    Channels: Enbled, No Exit Delay, No Entrance Delay, N.O., COntinuious -
    Dial and message heard but called phone rings and immediately the unit
    hangs up.
  4. Crash Gordon
    Crash Gordon Guest
    Will that seize the phone line for 10 minutes??
    Just asking...cause I'd never install on of those...curious.
    **Crash Gordon**
  5. Frank Olson
    Frank Olson Guest
    With no power to the phone, I don't think 1#1# (or any other
    combination) will work to restore the seized line. This could be
    dangerous for the end user as he's unable to use his phone for ten
    minutes. Not all carry cells.
  6. mleuck
    mleuck Guest
    The relay would be open for 10 minutes not the phone line, a problem
    with multiple alarms if the dialer can't call again because the relay
    that activates it is still open
    If it takes a 10 minute relay activation to get a dialer to send
    signals either ditch the dialer or learn to program it properly, since
    the 2001 has a momentary or maintained activation that shouldn't be
    too difficult even for Robert
  7. carolinaoff
    carolinaoff Guest
    I believe it is set up correctly:
    Channels: Enbled, No Exit Delay, No Entrance Delay, N.O., Continuious
    (tried momentary also - same result).
    hangs up.
    Question is - is this a symptom of a broken dialer?
  8. mleuck
    mleuck Guest
    A broken dialer won't dial Is step 2 Pager set to no? You also may
    need to program several P pauses after the phone number
