ADE7758 Energy meter calculations help
Discussion in 'General Electronics Discussion' started by salmanmahmood, Aug 17, 2012.
  1. salmanmahmood
    salmanmahmood
    Aug 17, 2012
    I am working on a project of energy meter. The task is to measure the active energy and then show the output on an LCD. The datasheet for meter IC can be found at the following link:
    http://www.analog.com/static/importe...ts/ADE7758.pdf
    In addition to this, I am using PIC18F4520 microcontroller with this system.
    The problem I am facing is that Vrms and Irms values that are obtained in the output are not accurate. Perhaps this is due to the gain calibration Irms and Vrms Offsets. Kindly help me out.
    Thanks in advance.
  2. CDRIVE
    4,960
    651
    May 8, 2012
    That link didn't load.
  3. salmanmahmood
    salmanmahmood
    Aug 17, 2012
  4. (*steve*)
    25,480
    2,827
    OK, Can you show us the circuit you're using, and some data.
    Let's look at voltage first. Some samples of different input voltages and what the device reports.
