Additional pass through transistor or bigger reg?
Discussion in 'General Electronics Discussion' started by Balrock, Aug 7, 2012.
  1. Balrock
    Balrock
    39
    Mar 1, 2012
    I have been moving forward with my Bench PSU project and had a look today at increasing its current output. My design (still in breadboard stage) uses LM317 and LM337 regulators so it can provide about 1.5 amp. I was looking at increasing this to around 3 amp.
    One option I have looked at is using the same regulators with the addition of pass through "power" transistors. The other option is to use higher rated regulators. What are the pros and cons of each approach.
    Thanks for any help given, Paul
  2. davenn
    davenn Moderator
    13,901
    1,971
    Hi Paul
    The LM338 will happily do up to 5 Amps, dont forget to heatsink it.
    messing around with lower rated regulator will work well its just a heck of a lot more work and higher component count.
    There's no point with pass transistors unless you are wanting over 5Amps, why complicate things more ?? :)
  3. Balrock
    Balrock
    39
    Mar 1, 2012
    Hi Dave. Thanks for the quick reply. Yes I looked at the LM338 but they don't make a negative version of it as my PSU is Dual Rail.
    However, I am using 2 x transformers wired together (as I got them cheap) in place of one single unit so would I be correct in saying that if I separate (isolate) and use one transformer per LM338 rail I could wire the + output of the second LM338 to GND (0v) of the first and I would get a dual rail + GND - type configuration.
    I hope that made sense!
  4. davenn
    davenn Moderator
    13,901
    1,971
    ahhhh ok, you didnt state anything about a split rail supply in your first post ;)
  5. davenn
    davenn Moderator
    13,901
    1,971
    OK here's one example along the lines of what you were thinking
    NOTE there is NO connection between the secondaries of the transformer
    [​IMG]
    this came from the www site, down the page a little way .....
    http://www.tcaas.btinternet.co.uk/jlhesl.htm
    cheers
  6. alfa88
    alfa88
    344
    5
    Dec 1, 2010
    Take a look at my project log. I just posted it a couple of days ago. It uses 2- lm338s. As long as the 2 secondaries are not connected to each other; who needs a negative regulator? I might have gone a little overboard on the heatsinks but that's what I had laying around .
  7. davenn
    davenn Moderator
    13,901
    1,971
    yup thats what the circuit does that I posted before your post lol ;)
  8. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    The bridge rectifiers must be connected correctly. It would be better to rotate the diode symbol a quarter turn to the left.
  9. (*steve*)
    25,500
    2,840
    Well spotted.
  10. Balrock
    Balrock
    39
    Mar 1, 2012
    Thanks all! I love this forum! What sweet headache relief it brings :D
    Sorry Dave, but in my defense I did quote "uses LM317 and LM337 regulators" ;)
    I will forge ahead to my next tangled web of confusion. Thanks again guys.
    "NOTE there is NO connection between the secondaries of the transformer" is ok for me Dave as I am actually using 2 smaller transformers anyway.
  11. davenn
    davenn Moderator
    13,901
    1,971
    yeah till i googled the LM337 I didnt realise it was a neg rail regulator .... never had the need to use one lol
    D
