Adding volume control to stereo
Discussion in 'Electronic Basics' started by Brent, Jan 20, 2004.
  1. Brent
    Brent Guest
    My mom has a late 80's sounddesign stereo that has two separate
    sliders for L/R volume. It's hard to control so I want to add a knob,
    and have it combined for the L/R channels. I need a pot right? How
    do I know what size to use?
    Will any of these work?
    http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3
  2. I imagine you have no diagram so the best thing would be to see what values
    are used on the existing controls.
  3. JeffM
    JeffM Guest
  4. Ross Mac
    Ross Mac Guest
    You could go a couple ways here. First you could post this one to
    sci.electronics.repair and find someone with a schematic and pick your parts
    from there. Or you could just measure the resistance with an ohmmeter and do
    a best guess on the wattage. Then purchase a good quality pot with dual
    wipers or a step attenuator would be nice too. Model numbers might help a
    lot also. Does that help at all ??.......good luck, Ross
  5. Quack
    Quack Guest
    pull the wires of one channel's slider and attach 'em to the other -
    wouldnt that then control both with the 1 ?
    or if you want the l/r balance to stay usable - then even pulling them
    both to a single pot wont help you.
  6. You use a dual pot with a single shaft. It has to be an audio taper,
    or a "log" pot. The resistance of the old pots should be marked on the
    body. 10K, 20 K 50K and 100K are common values for a volume control.
  7. Ross Mac
    Ross Mac Guest
    Ah yes, the audio taper...forgot to add that!!
