Adding up Voltage
Discussion in 'General Electronics Discussion' started by henrib736, May 26, 2013.
  1. henrib736
    henrib736
    12
    May 25, 2013
    Hi everyone,
    Consider the circuit here:
    When two sources are in a parallel circuit, their voltages add up, right?
    So I have a 0.5 volt battery and a 4700MF capacitor with a charge of 0.5 volts, but when I measure the voltage at h and z, the voltage is still 0.5 volts.
    Do you know what is wrong with this circuit?
    Thanks for reading.
    Henri
  2. (*steve*)
    25,501
    2,841
    No, when in parallel, the voltages are always the same.
  3. henrib736
    henrib736
    12
    May 25, 2013
    So do the voltages add up when they are in series?
  4. (*steve*)
    25,501
    2,841
    That is correct.
  5. davenn
    davenn Moderator
    13,930
    1,981
    except dont try that with a battery and a capacitor ... it wont work, you will get 0V as current doesnt flow through a capacitor.
    but if it was 2 x 1.5V batteries in series, then you would have 3V total :)
  6. henrib736
    henrib736
    12
    May 25, 2013
    Thank you!
