fazidurrani
- Apr 2, 2017
- 4
- Joined
- Apr 2, 2017
- Messages
- 4
Hi All,
I am new to Electronics and have some basic understanding. I've a subwoofer with builtin amplifier which has 8 pin din connector to connect to right satellite speaker. Right satellite speaker has RCA input jacks, volume control and power button. Circuit in Right side speaker takes RCA and feed the input to subwoofer amplifier on pin 5 and 6. pin no 7 feeds the amplified output to right speaker.
I've lost satellite speakers and now want to install RCA pins in the subwoofer box. So, i can use subwoofer with any aftermarket speakers. I've technical guide available but need guidance on how to do it?
I don't necessarily need volume functionality. i just want to install female RCA pins in the subwoofer and want to know if i can splice connections directly to pin 5 and 6 or do i need to add additional components. how i will feed the power to the subwoofer main IC?
Here is the link to the manual of circuit design (Both subwoofer and satellite speakers.)
https://www.dropbox.com/s/j7tt82c7sfy2yje/YST-MS50.pdf?dl=0
Alternatively, can i install this in the car? how i can setup the power source from car battery? any help would be much appreciated. thank you
