Adding dual-voltage to an SPS?
Discussion in 'Electronic Repair' started by DaveC, Jun 28, 2004.
  1. DaveC
    DaveC Guest
    I've got a battery charger for a power tool. Input voltage is spec'd at only
    120 VAC.
    Is it reasonable to think about modifying the switching p.s. to encompass 240
    VAC as well? Or might one simply design an entire new one more easily (not
    that I'd even consider doing that...)?
    What's involved in modifying such a supply?
  2. Ken Taylor
    Ken Taylor Guest
    Buy a stepdown transformer. Attempting to modify the existing supply is not
    a reasonable proposition unless you know how to design switching supplies.
    Ken
  3. Sofie
    Sofie Guest
  4. Only easy solution would be if it already has a doubler/bridge input
    with a jumper to select 115 VAC (in) or 230 VAC (out). This would mean
    the chipper runs off ~300 VDC. If it runs off of ~150 VDC, probably no easy
    solution.
    --- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
    | Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
    Important: Anything sent to the email address in the message header is ignored.
    To contact me, please use the feedback form on the S.E.R FAQ Web sites.
  5. DaveC
    DaveC Guest
    Sam, I always appreciate your instructional answers. In this case, it was, to
    paraphrase, "Don't do it unless it's an easy mod, such as...".
    I tire so of responses such as "You fool! You will die!", which may be true,
    but that's my responsibility, isn't it. I want to know *why*, which you
    provided.
    Thanks again, Sam, for another *educated* answer.
