I thought I'd give an update on my results.
- The more copper is added, the harder it is for the mixture to flow. At 80-90% it really doesn't "flow" like solder anymore, it just fuses and generally stays in the same form as when wet -- assuming that you ramp the temp gradually like most reflow profiles.
- adding the copper powder to solder paste seems to increase the solder melting point.
- at ration of about 80% copper if I only heat to 183c, (the melting point if the tin/lead solder paste), then the mixture will harden and have the appearance of sandstone or grout, very rock-like.
- but looking at this mixture under a 40X scope, you can see thousand of small solder spheres with clumps of copper in between. So not much fusion or melting at this temp.
- raising the temp to about 215c will cause the solder to begin to flow. Under 40x scope it looks like irregular solder clumps that have mostly fused together. Only a very few spots of copper are visible.
- I found that I didn't need the copper to increase conductivity, the tin/lead solder was about the same level of conductivity.
- Lower ratio's - about 20 copper - didn't seem to affect the melting point or the physical characteristics, it still flowed like solder at 183c.
One concern I ad was that so much fine copper powder would disrupt the flux ratio and therefore the oxidation protection, and in fact when you mix 90% copper, the resulting paste is very dry, kind of like copper mud.
I talked to someone who does reflow for a living and he said that today's fluxes don't do much to prevent oxidation anyway as they are mostly rosin or tree sap. He said in the old days, fluxes used to contain acid and the soldered parts would come out clean and shiny as the acid killed the oxidation.
As a side experiment I got some Naval Jelly which I understand is mostly phosphric acid and used that as "flux" with about 10% solder paste and the rest copper powder. At about 215c this creates a dull, silver, rock-like result, but is still conductive. It's a more toxic process though because of the fumes from heating the acid. It's best to do this with good ventilation.
Thanks again to all for the inputs.
