adding components to pspice
Discussion in 'Electronic Basics' started by Kenny, May 29, 2004.
  1. Kenny
    Kenny Guest
    I would to know if it is possible to add components into pspice 9,2?
    I would like to add the LM2587 for drawing a circuit and this part is not
    included in pspice.
    I looked on their web site and there does not seem to be a part list
    database to add to the software.
    So anyone know how or know of a more complete software that does simulation
    thanks
    ken
  2. Jim Thompson
    Jim Thompson Guest
    Are you using PSpice Schematics or OrCAD Capture? Student or full
    version?
    ...Jim Thompson
  3. Kenny
    Kenny Guest
    pspsice student version
    so I guess I should change?
  4. Don Pearce
    Don Pearce Guest
    PSpice allows you to add library components, which although a bit
    fiddly is not really a problem. The simplest way is probably to get
    hold of the necessary subcircuit from the device manufacturer and add
    it with a text editor to one of the existing parts libraries. Then
    borrow a symbol from another op-amp to make the connections.
    d
    Pearce Consulting
    http://www.pearce.uk.com
  5. Yes. The SuperSpice demo allows far more components (30*25=750). It is
    also much, much easier to use. Adding new models is a simle drag an
    drop.
    Kevin Aylward
    http://www.anasoft.co.uk
  6. Jim Thompson
    Jim Thompson Guest
    [snip]
    I'm uncertain, but I don't believe you can add parts to the student
    version.
    ...Jim Thompson
  7. Kenny
    Kenny Guest
    Do I have to build what I want from scratch or do I download some file ? if
    so where ?
    K
  8. Activ8
    Activ8 Guest
    Component mfgs supply spice models/subcircuits and IIRC, you can
    just drag and drop them from explorer into SS.
  9. Yes.
    For .models symbols are automatically attached, for .subckts, it will
    take you via the GUI to select an existing symbol when you try to place
    the .subckts.
    Kevin Aylward
  10. Activ8
    Activ8 Guest
    totally painless and free as in free beer :)
  11. Kenny
    Kenny Guest
    Do you have a link where I can download this then ?
    thanks
    Ken
  12. Ammm....never read signatures?
    Kevin Aylward
  13. Activ8
    Activ8 Guest
    LOL! Do I need to read Kevin's reply?
  14. Kenny
    Kenny Guest
    ichhh .... I try that :)
    K
  15. legg
    legg Guest
    I believe the original enquiry was for models and subcircuit additions
    to pspice.
    Not SS.
    If you want him to follow your line of thougfht, you will have to
    explain the relationship between the two versions.
    RL
  16. Yes. And you point would be?
    Er.. It seemed pretty clear that the poster was asking where to download
    SS.
    ..you will have to
    Why?
    Kevin Aylward
  17. Sure you can! I wish he had said which one, though. The process is
    different whether it is Schematics or Capture.
    First, get a model for the part off the web somewhere. There are lots
    of different sources. When in doubt, go to the manufacturer... :cool:
    Give the file a .lib extension.
    In Schematics, go to File/Edit Library. This starts the symbol editor.
    Then, go to Part/Symbol wizard, choose From a model library, and
    follow the instructions.
    If you have Capture, start the PSpice Model Editor, and load the .lib
    you created. Go to File/Create Capture Part, and it will create a part
    for all the models in the library.
    That's it, pretty much...
  18. Jim Thompson
    Jim Thompson Guest
    Except that Capture SUCKS !-)
    ...Jim Thompson
