Adding an LED to a device
Jay Singh
Feb 8, 2016
3
Feb 8, 2016
3
Hello, I have a speed camera detector which makes a beeping sound and also flashes an LED when it picks up a speed camera. Unfortunately, the location of the LED is no good so I wanted to add an external one. I thought it would be best to attach it to the speaker as the LED is sometimes used for other things. I have attached an image of the device as I need help in figuring out where to solder the LED to.
Thanks for any help
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Not a very good idea to connect the LED to the "speaker".
Simply connect it instead of the present LED with 2 wires.
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Thanks for any help
You may not want to, but this is an ideal solution.
Particularly, because the voltage and current on a speaker may be higher than tolerable for an LED. The signal sent to the Speaker may not even power the LED, or if it does, might be too brief to notice.
You should use the existing LED output and either put an external LED directly on it (replacing the internal LED) , or use the output to trigger a transistor to light a higher power or additional LED. One way or another, this is the best output to use.
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
It looks like there are two LEDs and one of them is dual (capable of displaying three colors). If you plan to remote mount the dual unit, you'll need a compatible substitute, not just a single color LED.
davenn
14,261
14,261
Thanks for any help
I don't see a speed camera detector in that photo ????
I see a GPS or WiFi dongle for plugging into a computer via USB and I don't see a speaker
so can we start this thread again please
davenn
14,261
14,261
OK doing some googling
and have discovered that it is a GPS receiver, as suspected
http://www.gpsinforad.co.uk/default.html
and it is programmed with locations of speed cameras for the country of purchased so it warns you when you enter a zone with a radar / camera unit
It doesn't actually detect the radar ... unlike the usual radar detectors. It gives a general warning as your GPS mapping unit does from Navman, Garmin etc
The USB connection, I would assume would be to do location updates of radar traps
OK now we have that sorted, ;) ;)
as others have suggested connecting another LED across the appropriate existing one would be the best way
