Add DC offset to AC signal
Discussion in 'General Electronics Discussion' started by Ricperes, Jul 22, 2015.
  1. Ricperes
    Ricperes
    29
    Jul 20, 2015
    Hello, I want to add a 2.5V DC to a AC signal, how i can do it? Thanks
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Feed the signal through a capacitor and onto the centre of a potential divider or onto a voltage source with a series resistor set for 2.5 V.
    Adam
  3. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Capacitor or opamp.
    A capacitor will allow the ac signal to pass through, just make sure 2.5V is on the other side. Adam has suggestions for this.
    Additionally, you can use a 'summing' circuit which will utilize an opamp... it's overkill, but is another option. It would of course help to know why you want to do this.
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    And don't forget he might need a negative supply for the opamp also which could complicate matters.
    Adam
    Gryd3 likes this.
  5. BobK
    7,682
    1,688
    If do it without an op amp, you will probably need an op amp buffer in input or output or both anyway. A passive circuit will have low input impedance and high output impedance.
  6. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    Firstly you have to provide details of the AC signal, its frequency and amplitude.
    And how it is delivered.
