Add antenna to WESTEK RFA-110
Discussion in 'Radio and Wireless' started by digicle, Mar 22, 2021.
  1. digicle
    digicle
    Mar 22, 2021
    hi
    i know this post is quite old but i have a Westek RFA-110 i need to add an antenna the receiver, it
    will be mounted in a metal enclosure, i want to make sure the receiver has no problems receiving signals
    from the remote control which I've already added an antenna to. I'm going to use an old wireless router antenna. i just wanted to ask if you could tell me what component or circuit path i should solder the antenna's coax to. on the lower right of the receiver pcb there is a choke or coil with a transistor so I'm assuming that area is the R.F. please reply thanks a lot
  2. Harald Kapp
    11,155
    2,547
    Created new thread from these posts, moved to a better suiting forum category.
  3. Martaine2005
    Martaine2005
    3,309
    904
    May 12, 2015
    If you open the unit up, you will see where the existing antenna connections are.
    I presume you mean the added antenna will be mounted externally on the metal box?.
    I am not familiar with this set, do you know what frequency it uses?. If its 2.4GHz, you should be ok with an old 2.4GHz router antenna.
    Why are you putting it in a metal box?.
    Martin
  4. digicle
    digicle
    Mar 22, 2021
    here are two pics of the Westek RFA-110 receiver pcb the receiver is on the left in both pics, with the black ac output, i have found the antenna connections in the transmitter,
    but i cant find them in the receiver. any help would be greatly appreciated.
  5. Martaine2005
    Martaine2005
    3,309
    904
    May 12, 2015
    I can't be sure but may be the top left (red) tuned coil is the antenna.
    These units are probably 433MHz or similar.
    Be careful tinkering if plugged in, that's a capacitive dropper power supply.
    I'll wait and leave this to somebody knowledgeable with RF circuits.
    Martin
    davenn likes this.
