M
Marte Schwarz
hello all,
I have a little topic I couldn't understand completely (or as much I want to
As a rule of thumb it is well known to use a filter to cut all frequencies
above half the sample frequency. But I guess, there are cases that doesn't
need this or where the signals would be more real without this filter than
with such one. For example ECG-signals. A QRS complex has frequencies in the
range of over 100 Hz. But these frequencies where not stationary so one
criteria to construct alias is not present. But filtering these Signals to
avoid frequencies over half the sampling rate may extend the QRS and in this
case changes relevant parameters of the signal. In real world we often have
nonstationary signals in which aliasing would not be created by having
samplerates below the nyquist criteria. OK, we make errors having not enough
sampling rate, sure, but depending on the goal of the signal analysis, may
be it is sometimes better to take these errors and avoid others created from
(analog) filters.
Where is the error in this statement? Or is it correct? What do you think
about?
regards
Marte
(analog) filters.
about?
regards
Marte
