adc temperature problem
Discussion in 'Microcontrollers, Programming and IoT' started by gurjant.sandhu33, Feb 26, 2014.
  1. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    i have used the following code with my pic 16f73
    unsigned char myvalue;
    void main()
    org 0x10
    adcon0=0x85;
    adcon1=0x01;
    trisa=0xff;
    trisc=0x00;
    while(1)
    myvalue=adc_read(0);
    portc=myvalue;
    delay_ms(2000);
    but now i want to use it with pic 16f870
    but it is not showing the right output as pic 16f870 is 10 bit adc and pic 16f73 is 8 bit adc
    so is there any thing i can do to solve it and do i need to adjust the vref value for new pic
  2. kpatz
    kpatz
    329
    88
    Feb 24, 2014
    Assuming adc_read() returns the full 10-bit value, you could simply divide by 4 (or shift right 2) to make it an 8 bit value the same as your old PIC.
    Also, with ADFM = 0 (bit 7 of ADCON1), the result is placed with the 8 most significant bits in ADRESH and the 2 least significant bits in ADRESL, giving a result left shifted 6 bits. If you read ADRESH and ignore ADRESL, you'll get the equivalent of an 8-bit A/D conversion.
  3. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Great answer kpatz. Did you get the PM I sent you? Just below the Electronics Point banner at the top of any page, at the right side, click on Private Messages.
  4. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    is this code right
    void main()
    org 0x10
    adcon0=0x85;
    adcon1=0x01;
    trisa=0xff;
    trisc=0x00;
    while(1)
    myvalue=adc_read(0) >> 2;
    portc=myvalue;
    delay_ms(2000);
  5. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    please can you tell me the changes i need to make to ADRESH in code
  6. kpatz
    kpatz
    329
    88
    Feb 24, 2014
    I found documentation for ADC_Read() which is a MikroC library function. It returns a 10-bit A/D result so simply shift right 2, like in your example code:
    myvalue = ADC_Read(0) >> 2;
    should do the trick.
    BTW, since you're using the ADC library functions you should use ADC_Init() to set up the ADC instead of setting the ADCON registers yourself.
  7. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    yes, adc_read(0) is reading value from temperature sensor connected to the adc 0 port.
    but the code with myvalue=adresh didnt work
