Jamie Morken
I am using an ADC that has a quiescent current of 2mA and the voltage
reference chip I am using can supply 20mA so I would like to use it as the
supply to the ADC as well as the vref input. (only have 3cm by 3cm board
area) Would this be a bad idea? The ADC datasheet says that the vref input
can vary from 500mV to VCC, but I don't know if that is true at the uVolt
level?! The vref chip is +-1% at 5volts (+-500uV).
The ADC chip is the ADS8344:
http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=ADS8344
datasheet:
http://focus.ti.com/lit/ds/symlink/ads8344.pdf
cheers,
Jamie Morken
datasheet:
cheers,
Jamie Morken
