T
Tango2
I built a digitizer with an adc0831. I thought I had read a datasheet
saying that the max. on the input was 5 volts but read later that its
the supply voltage (6.3) plus 0.3 volts. I have a 1k resistor between
the signal source and the input pin. Fearing to smoke it i put in a
4.7v zener before the resistor. With the zener the pin is getting 4.25
volts. Without the zener its 5.7v. The source is was a 741 which
proved too noisy so I replaced them with TL071s.
1) What is actually the maximum voltage limit on the adc input?
2) Is the voltage without the zener likely to rise above the adc input
limit?
3) Please confirm for me (or not) that the resistor and zener are really
making up a voltage divider?
tango2
limit?
tango2
