ADC on PIC24FV16ka301
Discussion in 'Microcontrollers, Programming and IoT' started by jackthelad, Jan 19, 2012.
  1. jackthelad
    jackthelad
    Jan 19, 2012
    hello,
    I'm having some trouble getting the ADC to work on 16-bit PIC. I'm using C for the first time so i'm not quite sure were i'm going wrong.
    the aim of the program is to get a value with ADC and send it over the UART. I know the uart is functioning correctly. I think the problem is taking the 10-bit ADC result from the 16-bit register and putting it in the 8-bit transmit register. If someone could tell me how to do this it would be very much appriciated!
    Code:
    // ADC trial code
    //init ADC
    #include <p24fv16ka301.h>
    #define DELAY 3000
    void initADC(void)
    ANSBbits.ANSB2 = 1; // select analog input pins
    AD1CON1 = 0x00E0; // automatic conversion start after sampling
    AD1CSSL = 0; // no scanning required
    AD1CON2 = 0; // use MUXA, AVss and AVdd are used as Vref+/-
    AD1CON3 = 0x1F04; // Tsamp = 32 x Tad; Tad=125ns
    AD1CON1bits.ADON = 1; // turn on the ADC
    //Read from ADC
    int readADC(void)
    AD1CHS = 4; // 1. select analog input channel
    AD1CON1bits.SAMP = 1; // 2. start sampling
    while (!AD1CON1bits.DONE); // 3. wait for the conversion to complete
    return ADC1BUF0; // 4. read the conversion result
    } // readADC
    //set up UART
    void UART1Init(void)
       // Set up registers
       U1BRG 	=   12;	//set baud speed
       U1MODE	=	0x8000;	 //turn on module (all zero except enable bit)
       U1STA	=	0x400;// just enable transmitter
    //UART transmit function, parameter Ch is the character to send
    int UART1PutChar(int Ch)
       //transmit ONLY if TX buffer is empty
       while(U1STAbits.UTXBF == 1);
       U1TXREG = Ch;
    main(){
    	T1CON = 0x8030;
    	int result;
    	UART1Init();
    	initADC();
    	while(1){
    		while ( TMR1 < DELAY)
    	TMR1 = 0;
                     result =readADC(); // i think this line is the problem
    	UART1PutChar(result);
  2. jackthelad
    jackthelad
    Jan 19, 2012
    Have just corrected a problem with ADCON1. still not working though. please let me know if you have any ideas?
