john
Hello All,
I have following confusions and questions about ADC based system: I am
trying to find the two ADCs for the following specifications
1. The specifications of input analog signal are as follows
a. Frequency range # 1 : 500Hz to 5MHz
b. Frequency range # 2 : 30 KHz
c. Both signals are biphasic square wave
d. Amplitude : +/- 5 volts
2. Digital interface will be USB2.0 (480 Mbps). Planning to interface
the ADC digital bus with USB2.0.
I need to choose an ADC that can sample the input analog signal
efficiently and generate the desired data bit rate (which I do not
know exactly now).
Sampling Calculations:
I have worked with an ADC from Maxim (MAX 187). This chip can do
75Ksps. So, it might be ok with the input signal of frequency of
40KHz. The Nyquist theorem says that I can not read the frequency
higher that (fs / 2). So, the maximum output analog frequency that I
can read if 37.5 KHz. Am I correct?
Can anybody suggest the part for the Frequency range # 1?
My other question about sampling is that the square wave consists of
many frequency harmonics, what harmonic should be chosen for sampling
the fundamental, second or third?
Data Rate Calculations:
The Data rate of the USB2.0 IS 480Mbps and the MAX 187 is 12 bit /
sample ADC at 75Ksps. So, the digital output rate of the MAX187 will
be 900,000 bits/sec. Is this correct?
Now, if I divide 480 Mbps with 12 bits / sample, then USB2.0 can
support 40 Mbps. Is this correct?
I will appreciate of someone suggest some parts and clear few
designing principles regarding ADC for me.
John
know exactly now).
John
