Adaptive circuit for selection of rectifier topologies
Discussion in 'General Electronics Discussion' started by shaikss, Oct 24, 2013.
  1. shaikss
    shaikss
    6
    Aug 17, 2011
    I have attached the two topologies of rectifier. One works well for lower input amplitudes and the other for higher input amplitudes.
    In order to achieve max efficiency for low as well as higher input amplitudes, I need some adaptive control mechanism which can select rectifier topology based on input voltage.
    So, How can I select and design a control circuit which can select either of the topology based on the input voltage?
      File size:
      12 KB
      145
      File size:
      13.7 KB
      144
